usLEDsupply RGB DMX Decoder 3ch
usLEDsupply
FreeStyler Version: 3.3.2
Post by usLEDsupply »
Here is a Fixture for the usLEDsupply DMX Decoders 3ch RGB and will work for the 24ch Decoders as well just add 8 of them
DMX Decoder 3ch RGB.pff
Re: usLEDsupply RGB DMX Decoder 3ch
Please remove the zip file and upload an exported fixture file a PFF (click file then export) and it will include all images etc associated with your fixture when upload as a PFF
kevinle
Post by kevinle »
I stuffed up I purchased 24 led dmx rgb decoder drivers only problem is they are for analouge strips not digital. Can anybody point me in the direction of a dmx decoder driver for digital led strips. cheers
usLEDsupply
you have to get the right type of DMX Decoder for your strips as they only work with the same type
if you have the LPD-6803 Strips you would need these
http://www.usledsupply.com/shop/rgb-dmx ... coder.html
if you have the WS-2801 Strips you would need these
if you are not sure what ones you have look at the numbers printed on the chips on the strip
they should say 2801 or 6803 or there are a few other types as well
spankthafunk
Post by spankthafunk »
I'm so confused:
What's the difference between and analog and digital strips?
How many DMX channels do these converters handle, 3 or 24?
usLEDsupply
the analog strips all change at once
the digital strips you can control each led (or groups of 3 leds) depending on the model so you can create chase sequences and/or make every other one different colors
you can control 512 channels from each decoder
spankthafunk
How many channels are used in one strip? Or how many LEDs per decoder?
usLEDsupply
it depends on the model of strip
The 12V RGB Flexible LED Strip 16' Roll (Digital Point Control) (60x WS-2801 chips / 180 Led)
http://www.usledsupply.com/shop/12v-rgb ... -ip68.html
uses 180 channels per reel so you can only connect 2.84 reels to each decoder
The 5V RGB Flexible LED Strip 16' Roll (Digital Point Control) (160x WS-2801 chips / 160 Led)
http://www.usledsupply.com/shop/12v-rgb ... 68-5v.html
uses 480 channels per reel so you can only connect 1.06 reels to each decoder
The 12V RGB Flexible LED Strip 16' Roll (Digital Point Control) (40x LPD-6803 chips / 120 Led)
http://www.usledsupply.com/shop/12v-rgb ... oated.html
uses 120 channels per reel so you can only connect 4.27 reels to each decoder
spankthafunk
What's the difference in strips, brightness?
usLEDsupply
the brightness is about the same with both models the type of chip and weather each led is controllable or in groups of 3 leds
the 2801 chips have higher resolution 255 levels of brightness
where the 6803 chips only have 32 levels of brightness
spankthafunk
So all you need is:
16' Digital LED Strip (5v for individual led control)
DMX to 2801 Decoder
Power Supply
And you can control that whole strip via dmx? Is anything else needed besides wiring, tools, etc?
usLEDsupply
yes that is all you need (well other than a DMX Source with at least 480 channels available)
spankthafunk
Man that's a whole universe per 16' reel.
What are some of the programs used to control these as a matrix (for led signs, curtains, etc)?
usLEDsupply
yes you use universes very quickly with the 5v strips
you can use Freestyler if you only have one universe or Madrix or Sunlite or several other programs if you have more than one universe
of if you just want to run pre-programed shows then you can use a standalone controller like the
12V RGB LED Digital Point Controller 2801 with SD Card
http://www.usledsupply.com/shop/12v-rgb ... -card.html
here is a video of the 12v 6803 strips (every 3 leds)
http://www.youtube.com/watch?v=vg7f0ld-APk
spankthafunk
How does the SD card ones work? They're preprogrammed shows on the SD cards?
usLEDsupply
yes you use the included software to make whatever shows you want then save them to the sd card then use the remote to select the show you want to play
spankthafunk
The decoder has included software? Do you have a link to the software so I can see what it's capable of?
usLEDsupply
i sent you the link to download it
spankthafunk
Thank you! This is really interesting. Does it repeat the sequence over and over? (not at computer right now)
usLEDsupply
yes but you can make a really long or a short sequence
