First of all, I don't know where to place this topic so I put it here.
I have a bug; I'm running FreeStyler 3.4.6 with Programmable override buttons and submaster.
I copied all my shows in the submaster, and in the Programmable override buttons screen I added some options. One of those options is the movement of my scanners, that works perfect, so far, when I start a show with the submaster, the scanners do move, but 1 of 10 seconds it's jumps back en goes back to the movement again.
I have the scanners making a round with their mirror, so when I start a show, they keep doing that, and then in one second it makes another thing and goes back to making a round.
Does someone know what the problem is?
Sorry for horrible English, not my first-language.
[BUG] Scanners moves while running sequence
- FreeStyler Version: 3.4.6
- Spirit
- FreeStyler Version: 3.5.9
Re: [BUG] Scanners moves while running sequence
hi,
can you be a little more specifc.
or uploud the backup file that will make life allot easer
