Hello!
Im new to Freestyler, but have been working alot with Martin Lightjockey for the last couple of years. I Have a question for you freestyler geniuses.
In Lightjockey when i've created a sequence and i have saved it and I want to create another one, you just press "new sequence" all fixtures goes back to "dead". When I do the same thing in FS the sequence I just created stays in the memory for some reason and I have to restart FS to release all fixtures so I can create another sequence without the old one interfering.
Does not freestyler release all fixtures when making a new sequence or am I doing something wrong?
Im using 3.4.6 version.
//Kristoffer
After making seq, how release all fixtures? Topic is solved
Cooly
It's quite simple
In the "create sequence" window, click on "Transparent mode" label. You get a menu.
Now click on "clear all fixture when new pressed" (or something like
Edit : I just saw that you figured it out by yourself
kristoffer
Re: After making seq, how release all fixtures?
Another question thou.. Sometimes when I press "new sequence" some fixtures does not clear their memory. Anybody has a clue why? And what about the button "release all"?, It don't have a function at all? Cause nothing happens when I press it.
- Spirit
- FreeStyler Version: 3.5.9
oke if you open the create sequence window you will see Next to all the Slider "OFF"
this means that the channel is NOT recorded to a Sequence.
if you drag the slider it changes to "FADE" this means it will fade from one Value to the Next.
And if you press on the "Fade" button you will see "SNAP" that means it will Jump from one Value to the next.
Now if you Press "New sequence" all the channel will go Back to "OFF"
and as Cooly says if you press on "Transparent mode" there will be more options.
and you can Enable "Clear channelvalues when "New" Clicked" this will set all the channel values back to "0"
and Release all is used durring playback if you make a Manual override you can Release it if you press on "Release all"
