Hi
I have been trying put freestyler for about a week now with 4 scanner connected before i use it on the full rig of scanners, par cans, led bars, dimmer packs etc in a new nightclub and live venu we are opening.
I can setup and create a sequence using the FX button within the sequence editor to make the 4 scanners chnange colour, 4 steps as follows
RRRG
RGRR
RRGR
GRRR
r = red
g = green
i can adjust the step time and everything else i want to however, i cannot find a way to add this sequence along with other colour sequences and ones for movement, gobos etc onto some kind of simple interface which the DJ's can use.
Im open to suggestions but midi keyboard, pc keyboard, big grid for a touch screen (like martin light jockey) are all options i can use if required.
Thanks for help anyomne can provide.
Simple playback of sequences Topic is solved
- Spirit
- FreeStyler Version: 3.5.9
Re: Simple playback of sequences
There a Many ways to Playback your Sequence.
Like the Overridebuttons For static Values (Only the First step / Chapes)
Cue window to Playback Sequences With more steps.
Cuelist buttons, Press a Button and your Premade Show will Playback.
Or the Submaster also used by the Proffesional lighting poeple.
And you can indeed use a Midi controller, Keyboard, Mouse, you can also use Touchscreen userinterface 1 or 2 , (1= a Premade Interface 2= You can Create your own interface.
But also with Wireless Devices, like Ipad, iphone, blackbarry or Android.
look at the Wiki : http://www.freestylersupport.com/wiki/ and hopefully you can find your way.
/Spirit
/Spirit
