I have a couple of par36's en put them in groups.
Now in touchscreen UI2 i can select groups, like all groups or just group 1 & 3.
Is it possible to use the macro function here ?
Like i want group 1 & 3 to be red and group 2 & 4 green.
I can't find any option to activate a macro.
I noticed i can use the sliders to set colors to 1 or multiple groups, but i would like to use a predefined set of values like a macro.
Anyone know how to do that ?
Thanks,
Ed
Using Touchscreen UI2 with macro ? Topic is solved
- Spirit
- FreeStyler Version: 3.5.9
Re: Using Touchscreen UI2 with macro ?
Hej knight,
No there is no Macro function on the TUI2.
The only way you can do it is to create Each color on a Seperate Sequence, with all the Fixtures selected.
Then you can add this to the Override buttons, and if you select a Override button with the rightmouse button you have some extra option, and you select "Selected fixtures only" you need to do this for each override button.
and try again, But it still does not Realy react the same as the Macro's.
But if you only use the groups 1&3 and 2&4.
i would recommend to use sequences With the those Groups, but if you allways like yo Use differnt groups mixed witheach other, then it will be realy hard to get this, Exept the Macro's.
/Spirit
/Spirit
