Easy View ????
Easy View ????
Hello,
Here's another chance to show my complete and utter ignorance regarding this stuff, but I gotta ask a couple questions...
What is the purpose and function of Magic 3D Easy View? What does it do?
I can open it in demo mode (no USB DMX interface yet)... I look to add fixtures just for grins and here's this HUGE library of fixtures... and the program knows what they do.
So, if this application is integrated (to some point?) in Freestyler, why can't the fixture library from Easy View be integrated into the fixture library of Freestyler?
Please share some examples of what it can/will do to help control DMX lighting.
Thanks so much!
steve
Thanks so much!
steve
- dmxlighting
- FreeStyler Version: beta
Re: Easy View ????
if you open easy view from inside freestyler and you have any FS supported usb/dmx devive or you set fs to have a virtual device then you can use ev to constuct a 3D version of a stage or rig and see the beams!
Well worth learing to use, will take some time to get into though!
Good luck.
PS limited mode will be enough for you to do most stuff. Full mode requires a Sunlite device.
Good luck.
Re: Easy View ????
Thanks, dmxlighting... by Sunlight device, do you mean a Sunlight USB DMX dongle?
Will the stage setup in ev display and run the program you run from FS?
- Spirit
- FreeStyler Version: 3.5.9
Re: Easy View ????
Yes the Sunlight DMX in Dongle.by Sunlight device, do you mean a Sunlight USB DMX dongle?
Yes Offcourse That the Whole idea about 3dview.Will the stage setup in ev display and run the program you run from FS?
Re: Easy View ????
Thanks so much for the answers. My Entec pro is supposed to be delivered today, so I'm digging in. I hope someone checks out my fixture file.
Time for the FS tutorials!
steve
steve
- Spirit
Re: Easy View ????
But if you installed freestyler with 3dView you need to Select "Virtual interface"as your interface.
This way you can use the 3d view that comes with freetyler. only you will run in Limited Mode.
Re: Easy View ????
That's exactly how I have been *using* it... limited mode, just looking around seeing what's there and what they do... add fixtures, objects, etc to the stage. Just starting the feel my way around in it.
steve
steve
- dmxlighting
Re: Easy View ????
Yes you need a genuine Sunlite devive. They actually do a special, slightly cheaper on for 3d developers like me but that does not output any DMX signals.skintner wrote:Thanks, dmxlighting... by Sunlight device, do you mean a Sunlight USB DMX dongle?
Yes EV will work very well with FS.
To save on processor power I run FS from my laptop and EV from my desktop (which has a really good graphics card, which really helps!) My laptop has an enttec pro device which is then conneted to the DMX in on my sunlite device on the desktop.
- dmxlighting
Re: Easy View ????
Spirit wrote:But if you installed freestyler with 3dView you need to Select "Virtual interface"as your interface.
FS doest need to be in Virtual Mode once you have a compatable device conneted and set up. That way you can if needed run EV and operate the lights in real time. This is quite handy for DJs who are normally behind the lights and cant see so well what they are doing. If EV is the same setup as the acual lights then this is great! Also you can use EV to make changes or create new sequencies that the audience does not see. This works when FS's save window comes up in 'off-line mode'. Not output to the lights will change but EV will show what you are doing. Reallyt cool feature that not many people seem to know about!
- dmxlighting
Re: Easy View ????
Thats the best way! Working in 3D is a bit strange to begin with but you soon get used to it!skintner wrote:That's exactly how I have been *using* it... limited mode, just looking around seeing what's there and what they do... add fixtures, objects, etc to the stage. Just starting the feel my way around in it.
steve
Let me know if you get stuck and I'll try and help you out.
- FreeStyler Version: 3.4.6
Re: Easy View ????
I am new to using freestyler. I am used to using an actual lighting bored...mostly for led lights for my church. Recently we have used a lot of our extra lights in our youth room with just simple dip switch colors. So, I decided to purchase a gus electronics usb/dmx dongle and downloaded freestyler to have the capability of running the lights. I have had 2 weeks with the program and have learned a lot by just playing around with it and watching some Youtube videos. I was also able to get some help from spirit on another post. my question here is about EV specifically. I have built my stage and added all the lights that I am to be using. It didnt work at first but I read where it had to be on virtual interface and to make sure I had the dimmer up. So I did these and it has worked great and I love it for being able to set up shows without actually being in the room with the lights. My question is...can I not run EV while actually running my show? I switched it back over the the gus electronic output and my lights will come on but EV stops working. Is the gus electronics dongle not compatible to where I can do that? It would be awesome if I could get it all working together. Thanks for the help!
Bobby
Bobby
- Spirit
Re: Easy View ????
Hi.
No its just EV or Gus electronics.
/Spirit
/Spirit
Re: Easy View ????
Awww bummer... Oh well. Thanks for the quick reply spirit.
Bobby
Bobby
- dmxlighting
Re: Easy View ????
Spirit wrote:Hi.
/Spirit
That should not be the case. EV should work with a dongle. I have had it running during a show where I could not see the stage properly. Devices used and proved to work were enttec pro and a soundlight device.
Also FS was made to work in 'offline mode' - meaning that you can edit sequencies on the fly (during a show) without the audience seeing that. This is done by using EV which will work in offline and show what you are editing / creating.
- Spirit
Re: Easy View ????
Oke sorry.
For FREE you can use 3d view or your DMX device.
as DMXlighting says you can also Spend 300 Euro For 3dview and you will get a DMX-IN device So you can make the Dmx chain From you DMX-out thru all the Fixture and then to the DMX-in device.
- dmxlighting
Re: Easy View ????
Im pretty sure that even in limited mode you should be able to use both you're device and EV.
I have defianatly done so. It might not work for all devices and it was a while ago so maybe now EV has had a face lift and quite a few changes it don't work anymore ? It did used to work perfecty well in limited mode doing this with Enttec Pro and an old Soundlight device. I will try it again and report back.
- dmxlighting
Re: Easy View ????
OK tried it with enttec pro and you can operate your lights AND see the EV visulization at the same time.
The offline thing I spoke about does NOT seem to work anymore.
I will further test this with other devices when I get time but im sure it will work.
Id be interested to here from others with different devices as to wether this works for you.
- Spirit
Re: Easy View ????
Oke but still you need two Devices and link then on eachother..?
And as i sad before, Many thing Seems to not work anymore on EV.
But as i see now there is a New version From EV updated 27-01-2012..
Lets see if that makes the differnt.
- dmxlighting
Re: Easy View ????
No. Just one device. It works for me in limited mode!Spirit wrote:Oke but still you need two Devices and link then on eachother..?
Please try and report back
- Spirit
Re: Easy View ????
Oww yes indeed It works.
Thank you thats a Good point for the wiki
- dmxlighting
Re: Easy View ????
Spirit wrote:Oww yes indeed It works.
DMXlighting - Making the impossible possible !
Re: Easy View ????
So, did downloading the update for easy viewer help with the problem? I still have yet to get it to function simultaneously using my gus electronics dongle : (
- Spirit
Re: Easy View ????
i tested without the new Vesion from EV.
I Connected and selected my Enttec Pro as Interface opent EV and Both where running.
Thats all..
Thats all..
Re: Easy View ????
Bummer....it must be the dongle I am using : (
