hello when I go to edit the sequence can not see the changes I make,
moving the parameters on the monitor, I did not change output
software 3.4.6
problems edit sequence Topic is solved
- Spirit
- FreeStyler Version: 3.5.9
Re: problems edit sequence
If you have the Cue window open, and you open the Create sequence window it will be opent in OFFLINE mode. and if its in OFFLINE mode you will not see any changes in the Output window.
/Spirit
/Spirit
peolo
If I have to edit a sequence, how can I see the change that I make .
If I have to change as pan or tilt in a scene as I see the right point
thanks
thanks
- Spirit
Oke Durring Playback It's not possible to See what you do if you like to change/Create a Sequence.
Durring playback = If the CUE window is open And Sequence Creator Says OFFLINE
If the Cue window is Closed and you open Sequence Creator you can see the Change you make.
Also Sequence creator will not say its in Offline mode.
- dmxlighting
- FreeStyler Version: beta
You CAN see the changes if you are running Sunlite Magic 3D visuliser which is setup the same as the show you are running. Then in offline mode you can create / edit anything and it wont change what the audience see but you can see it on screen! Clever stuff really!Spirit wrote:Oke Durring Playback It's not possible to See what you do if you like to change/Create a Sequence.
