Hi!
I created fixture profile for light described above.
Gobo set icons are included, colours are used from original Freestyer sources.
This profile is tested and working on Freestyler 3.4.4 !
Enjoy!
Jozo Mituch
PS: only for sure: Original operator's manual is avaiable there: http://www.robe.cz/products/article/clubscan-250-ct/
Robe Clubscan 250 CT
jozo.mituch
Robe Clubscan 250 CT.pff- Single archieve - just download & doubleclick :)
- (80.36 KiB) Downloaded 137 times
ROBE Clubscan 250 CT - ver 1.0.rar- Archieve with separate files (for future developers)
- (19.86 KiB) Downloaded 81 times
- Spirit
- FreeStyler Version: 3.5.9
Re: Robe Clubscan 250 CT
Hej jozo.mituch
I have seen you made a real nice zip file with everything in it But Fixture Creator got his own"Sort of Zip file its a .PFF FIle.
If you open fixture creator and press on File and then on "EXPORT" you can Export you fixture file to a PFF file.
and a PFF can contane Fixt.Picture, Custom gobo's, custom Colors.
Just everything custom you made.
and the nice thing about it is if you open a .PFF file everything will be extract at the Corect location
So there is no README needed
/Spirit
/Spirit
