is there any way to auto map the bcf2000 to the selected fixtures?
so when i select my par cans i can control the the pars with my bcf, when i select scanners i only control the scanners with it....
thx in advance
Use BCF2000 with selected fixtures
- FreeStyler Version: 3.0
- Spirit
- FreeStyler Version: 3.5.9
Re: Use BCF2000 with selected fixtures
Hello, steven789
Yes this is possible, only it bepant on what you mean with.
during playback or programming?
how do you like to control your fixtures?when i select scanners i only control the scanners with it....
for example i am in programming mode, i select my par cans(6ch).
can freestyler automatically assings the first 6 faders to the par cans?
then i deselect my parcans and select my movingheads 8ch
can freestyler automatically assings the 8 faders to the movinghead ...
- Spirit
hello, steven789
yes this is possible, only with the moving/scanner but with the parcans its alittle bit tricky.
http://www.freestylersupport.com/wiki/e ... re_control
here you can see all the fixture controls.
and you need the pan/tilt/prism/gobo/color/iris/focus channel
