More than 1 beam?
Asa_Js
More than 1 beam?
Post by Asa_Js »
I have been trying to get the multi beam bit to work in the fixture creator and although adding more than one beam I don't see them.
Is this option for the future or am I missing something?
Re: More than 1 beam?
Hello, Asa_Js
Yes and no, if you open the Scanlib and make a new Fixture you will see it's possible to add more beams or lights.
but if you add the multibeam light to 3d easyview you'll see it's doesn't Work.
But allways keep in mind It's just a Simulator, allot of stuff doesn't work how it should be.
Like: P/T Speed doesn't work
Iris isn't placed good (or bepant on the fixture you controll)
3dView is just a proram to give you a idea what your doing, it also runs in "Limited Mode"
/Spirit
Asa_Js
Post by Asa_Js »
Sure...but it is meant to do it, the web nicolaudie.com describes it and it is in the tutorials. This is also not a limitation of the limited version.
Can you get me a URl i lookt at it but can't find any info about that.
