Gobos to buy
Gobos to buy
I was wondering where you can purchase just basic Gobos? I am not wanting anything fancy, I just couldn't find a site that sells Gobos for a Martin for under $10 each. They are simply a piece of steel really thin...
- Admin
- FreeStyler Version: NULL
Re: Gobos to buy
check ebay, also there is a site... if i rember it i will post it
Matt Hankosky
flickr.com/photos/mattxhank
Re: Gobos to buy
I have looked and found a few things on ebay, but nothing really worth considering. Is there something else they are called? Has anyone here changed out the Gobos to something else? I just want some different effects, not like a custom Gobo with my company on it.
- Admin
Re: Gobos to buy
Matt Hankosky
