*Request* fixture files for Chauvet intimidator Scan LED Topic is solved
DJ_gh0st
i need the files for chauvet intimidator scan led if anyone has this?
- Spirit
- FreeStyler Version: 3.5.9
Re: *Request* fixture files for Chauvet intimidator Scan LED
Welcom to the Freestyler forum
you can find Fixtures made by users here http://www.freestylersupport.com/fsforu ... m.php?f=23
Here is the Chauvet intimidator
1) http://www.freestylersupport.com/fsforu ... =62&t=3495
2) http://www.freestylersupport.com/fsforu ... =62&t=1620
3) http://www.freestylersupport.com/fsforu ... =62&t=1555
I'm not sure if it's the led version
and here is the Min spot
http://www.freestylersupport.com/fsforu ... =62&t=1914
otherwise you need to make the fixture your self you can find info here : http://www.freestylersupport.com/wiki/fixture_creator
if you don't get it to work you can ask advice.
BUT if your going to ask advice plaese post the Manaul or .pdf
Kind regards, Spirit
DJ_gh0st
DMX Channel Summary - 13 Channel Mode
CHANNEL
FUNCTION
1
Pan
2
Pan Fine
3
Tilt
4
Tilt Fine
5
Vector Speed (Pan/Tilt)
6
Dimmer/Strobe
7
Red
8
Green
9
Blue
10
Color Macros
11
Vector Speed (Color)
12
Movement Macros
13
Gobo
CHANNEL
FUNCTION
1
Pan
2
Pan Fine
3
Tilt
4
Tilt Fine
5
6
Dimmer/Strobe
7
Red
8
Green
9
Blue
10
Color Macros
11
12
Movement Macros
13
Gobo
DJ_gh0st
ooooops sorry i posted that wrong
highvoltageboston
Did you ever find the files or successfully create them?
Tascam
Spirit wrote:Welcom to the Freestyler forum
These are for the Chauvet Intimidator Spot and 2.0
I would like to have a profile for the Chauvet Intimidator Scan 200 LED. Thanks in advance for your help.
Tascam
Anyone? Can I pay someone for a profile please?
Can I also pay someone for a profile for a Venue ThinPAR 64?
Thanks.
Thanks.
gta1200
I have made files for the Scan LED 100. I assume they are the same DMX. Only channel I haven't done is channel 6, the gobo rotate just becausee I haven't figured it out yet on fixture creator, If I fix it, I will update it.
To install:
Unzip and copy files to C:\FreeStyler\Fixtures
Open Freestyler and search for Intimidator Scan LED 100
Enjoy!
To install:
Enjoy!
Chauvet Intimidator Scan LED 100.zip- (10.55 KiB) Downloaded 64 times
jan1kow
I done same for LED 100.
will compare mines to yours later and let you know if there are any differences.
jon
UK
jon
UK
Nathanrs93
- FreeStyler Version: None
If any of you did want a fixture creating for a set price, then look here: http://www.ctwo12.com/freestyler-fixtures/
jan1kow
Hi GTA 100.
Have compared intimidator led 100 to my version. I had shutter open values reversed so have changed. Thanks
You have number of gobos as 7 but I had 10 as I saw on utube you should count all channel 5 functions. If this is correct you missed 000-029 open white, 240-249 gobo rotate and 250-255 sound mode. I too am stuck with gobo rotate. May be template is missing this option for values 010-255?
jonk
jonk
