i want to use my Kontrol S4 as an external midi device.
The problem is, that i.e. the 4 linefaders in the middle all send note 69 but on different midi channels (channel 1 for A, 2 for B and so on).
When i want FS to learn these faders, it only recognizes midi note 69 and the correct value.
The Channel column stays at n/a.
Does anyone know how i can get FS to learn the channel (or change them manually)?
I'm using 3.4 beta.
Traktor Kontrol S4 Midi Channel
- LJ_krede.dk
- FreeStyler Version: 3.3.7
Re: Traktor Kontrol S4 Midi Channel
the channel column is for when you assign "MIDI to DMX only", here you enter which DMX channel the assgined fader/encoder shpuld control. thats why it is "Not Available" for the other MIDI functions... FS should recognize which MIDI channel the faders are on so it should work.
try again and write if it is still not working,,, then we find a solution
/LJ_krede.dk
Aalborg, Denmark
Aalborg, Denmark
