I am developing a software shell for controlling Freestyler. I will tell you a lot more about it - but I would like some hints on how to implement a simple MIDI trigger solution. I've looked into "Pure Midi" and "Midi Toolkit", but both seems to be overkill for a simple solution of catching Midi events to trigger Freestyler.
So - does anyone have suggestion for a simple Midi trigger solution?
2011-06-05-SOLVED
Although there was no simple solution I have managed to Implement MIDI.
/Magnus
MIDI programming
Starcruiser
- FreeStyler Version: 3.2.8
