auto bulb strike?
gareth
FreeStyler Version: 3
auto bulb strike?
Post by gareth »
hello,
i have 3 matrin roboscan 512's and the bulbs don't strike untill told. so every time i start freestyler i have to tell them to strike. i was wondering is there any way to make freestyler tell them to strike when the program loads? it would be fine if it was just me using the program but where the lights are used by other people as well its a bit of a pain because some of them don't have a clue how to use freestyler even once you have shown them lol
cheers
FreeStyler Version: 3.3.7
Re: auto bulb strike?
Post by LJ_krede.dk »
you can change the deafult startup values for the wanted fixtures by opening the fixture files in fixture creator and change the default values for the lamp channel and/or others if needed (like position, focus, colour etc)
/LJ_krede.dk
Aalborg, Denmark
gareth
Post by gareth »
ah yes, did not think of that :) thanks
