Please More Advanced Keyboard Shortcut Controls
Pmarten8
Post by Pmarten8 »
Can Freestyler be given some more advanced keyboard controls focused on the fixtures functions
I been trying to configure the keyboard shortcuts to control all the features of a fixture but so far
i can only control the: gobo, colour, pan & tilt, next and previous fixture
Could not find and option for configuring:
  • lamp Open & Close (Critical Missing Option) YOU CAN OPEN THE MENU BUT NO CONTROL OVER OPTION LAMP OPEN OR CLOSED
    Strobe Low Med High (multiply BTN Tap)
    Focus In/Out
    Iris Open/Close
Think some may need advanced configuration that will allow multiple button tap so it can select Low, Med & High and then back to Low
wardomon
Re: Please More Advanced Keyboard Shortcut Controls
Post by wardomon »
Put me on that list.
I'd also like to be able to save and load cue list tabs. It would make rearranging locations (song lists) much easier. It's annoying to have to drop 16 cues onto individual buttons rather than load the whole tab at once. I put in a feature request but was turned down.
SmallBand
Post by SmallBand »
Did we ever get an answer on this? I would really like this too
Return to “Ideas and Remarks”
