Why Magic 3D Easy View Work in Demo mode?
paoloduladj
FreeStyler Version: 3.3.2
Post by paoloduladj »
Hi to all.
I've download and install Magic 3D Easy View.
At first time, with my usb controller DMX, i am able to work whit it, but now the application work only in demo mode.
My USB to DMX Interface is the Velleman k8062 / VM116 (512 channels) and the version of Magic eD is Dec 13 2010.
Thank you very much for the answare.
fred
FreeStyler Version: 3.9
Re: Why Magic 3D Easy View Work in Demo mode?
Post by fred »
hi,
you have to choose "virtual interface" into frreestyler when you are disconnected from your lights (and not only from you open dmx) and after that try to use Magic just with 1 par to be sure that everything is well connected befaore to try with a lyre or scan which are more complicated.
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Post by matt »
Also,
Make sure you launch EasyView from inside of Freestyler (3D Icon). if you try to launch it separately it will not work.
Matt Hankosky
flickr.com/photos/mattxhank
