User created scene issue - Movement only jumps to first step
Matty
Post by Matty »
Hi!
Its my first post so hope I provide enough information for help. Im ussing Freestyler 3.3.6 and I have created some shapes/movements for my roboscans 812 that when I test through the scene/step creator they all jump to the correct posistions. I have saved the steps/scene and then added them to a button but when i press the button i have added them to, it only jumps to the first posistion and no further.
I have loaded the preset shapes to the buttons and they all work correctly.
Any ideas why this might be happening?
FreeStyler Version: 3.3.7
Re: User created scene issue - Movement only jumps to first
Post by LJ_krede.dk »
Hi Matty and welcome to the FS support forum
the override buttons only plays the first step in a sequence. The override buttons main purpose is to set "instant looks" like Flash/strobe, Colour, Position, blackout, gobo and so on. use the cue window and/or submasters to play the entire sequence
if you not already did it i will suggest you read the help file in FS and the FS wiki page to have a understanding what FS can do for you. if you still have question feel free to post them on this support forum.
/LJ_krede.dk
Aalborg, Denmark
Matty
Post by Matty »
Ah, I see! I did have a look but I have to say that becuase I could set the preset shapes as override buttons and they all worked fine that I thought there must be a way to do it! It threw me a little.
Thanks for your help and a nice quick response!
I can see why you were confused.. a shape is only one step sequence, thats why it works on the override buttons..
i'm glad i could help... feel free to ask again if needed
/LJ_krede.dk
Aalborg, Denmark
