can only be uninstalled from a 64 bit OS
Bobby D
FreeStyler Version: 3.2
Post by Bobby D »
I've got freestyler installed on two laptops. One is 64 bit windows 7, the other is older with xp. After lots of programming on the win 7 laptop, I did a backup. I restored the backup on the xp laptop and updated the Sound to Light app. I inadvertently installed the sound to light program in to the wrong folder and just moved it to the freestyler folder.
The SL app isn't working and the lights kind of go haywire. Everything else is working fine on the xp machine. I tried to uninstall freestyler and it won't uninstall. The message says it can only be uninstalled from a 64 bit OS. Is there another way to uninstall FS so I can start over? Did transferring from the 64 bit machine cause this?
I'm really lovin' the latest SL app, but can't use it on the xp laptop :cry:
