I have some LED strips for which I have created a color changing sequence for.
I also have some moving head lights I'd like to use the shape generator with.
No when I enable the sequence for the LED's, the shape generator becomes de-activated.
How do I get around this? Also, can I save these as presets on a cue button?
Shape generator and sequence confusion... Topic is solved
Bobby D
Re: Shape generator and sequence confusion...
Did you make separate sequences, one for the moving heads and one for the strips? Or are you trying to add moving head shapes to another sequence?
I would make them separate and then put them both in one cue. That should work.
