Would it be possible to put back the ability to create macros for dimmers as on previous versions? I used to use these quite a lot for pre-heat, testing/focus etc. Also useful when using switch-packs, where a 'button' is much more use than a fader.
Cheers.
Fixture Creator - dimmer macros
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Fixture Creator - dimmer macros
I think it is still possible to create a fixture which is a dimmer. when in fixture creator slect custom instead of dimmer and the macros should still show.
p.k.roberts
Yes, that is a way to work around this, but it is a bit 'messy' and it seems a shame to have lost the function that was there on previous versions.
- Mattotone
send a feature request using the bug tracker, im sure its easy to add
p.k.roberts
Sorry, I'm not sure what the 'bug tracker' is - how do I do that?
in the top of this forum, click on the "Submit a Bug Reportp.k.roberts wrote:Sorry, I'm not sure what the 'bug tracker' is - how do I do that?
try to follow the guides in these two posts
FreeStyler Bug Tracker
New process for feature requests
FsBT cannot retrieve log in details from the Freestyler Support forum at the moment. so you have to make a new user. I recommend you use the same user name
