Fixture files for HQPOWER Topic is solved
karafan
Post by karafan »
HI,
I need fixture files for HQPOWER VDPL303BS & HQPOWER VDPL300BA
i have a dmx values for this machines.
very thanks.
FreeStyler Version: N/A
Re: Fixture files for HQPOWER
Post by remco_k »
Moved from "Help & Support" to "Fixture Requests".
karafan wrote: i have a dmx values for this machines.
So why didn't you post them?
If you do you have a slightly higher chance of someone helping you out.
But your best bet is to just try and create the fixture file yourself using the fixture creator and the fixtures manual.
If something doesn't work, you can ask in "Help & Support", supplying the manual, what fails and the exported *.pff file from the fixture creator so we can see things.
