I am looking for the manual for a Meierlight laser R G B
I am trying to create a fixture for it. I created one for a RGY earlier today, But this one is getting me
This is what i have so far not 100% its correct
24 Channels
1 Control
2 Control 2
3 Gobo 1 select
4 blanking rate ?
5 Color 1
6 unknown
7 Slow draw 1
8 Zoom 1
9 Rotate 1 < >
10 Rotate 1 ^ v
11 Spin 1
12 move 1 < >
13 move 1 ^ v
14 Gobo 2
15 Gobo 2 select 2
16 Color 2
17 unknown
18 slow draw 2
19 Zoom 2
20 rotate 2 < >
21 rotate 2 ^v
22 Spin 2
23 Move 2 < >
24 Move 2 ^ v
channels 3 -13 are for the first gobo / laser picture
channels 14-24 are for the 2nd gobo / laser picture
Meierlight Laser mid way Topic is solved
nickguk767
Re: Meierlight Laser mid way
Hey Kosh, I am struggling with a laser at the moment and you mentioned having made a profile for an RGY.......Have you uploaded it yet so I can download and have a look, and if you haven't, could you please? Thanks.
Kosh
yes I will, its a R G Y AT LASER i think Athen's II but not sure.
The gobo's are not 100% accurate, but very close
RGY AT Laser.pff- (410.05 KiB) Downloaded 64 times
nickguk767
Thanks for the post, Kosh.
It's interesting for me in that for the patterns you have given each one a single value(from 0 to 171). I have Googled for the manual for your laser but not found anything to see if that will work, but I am going to try re-doing mine with one value per pattern to see what happens.................What i have been doing is dividing the 255 by 50 patterns and then trying to assign dmx values in the resulting steps (roughly every 5) - i hope thats where i have been going wrong as i didn't appreciate that not all of the available 255 have to necessarily be used up!
I will let you know how i get on ................. I so want to nail this damn thing!!!!!!!
Happy New Year!
Happy New Year!
Kosh
This version is a bit better w/ gobos / colors etc
will get you through the night fairly well
RGB Laser Final.pff- (248.64 KiB) Downloaded 71 times
