Acme Miracled 4/7ch HELP Topic is solved
Pmarten8
Post by Pmarten8 »
Im struggling with this fixture ive done several other you can see on the downloads page there's 4 of my working ones
This has 4/7 channels
4 Channel Set-up
1--Mode
2--Pattern/Chase
3--Pattern Strobe/Chase Speed
4--Dimmer
7 Channel Set-up
1--Mode
2-5--Pattern/Chase
6--Pattern Strobe/Chase Speed
7--Dimmer
DMX 512 Configuration
http://prolight.co.uk/images/media/MIRA ... 01-um0.pdf
What i cannot work out with these is the gobos/patterns and the chase setting check the fixture file ive included im sure it some thing simple if i have another 5 different fixtures with similar setting and cannot work them out if some can help us out with this one i will upload the rest once i can get them made
Miracled 4ch.pff
(39.87 KiB) Downloaded 106 times
Miracled 7ch.pff
(39.9 KiB) Downloaded 92 times
Reason: Removed zip file attachment, please attach exported *.pff files only! They are zip archives and contain everything needed, including images.
FreeStyler Version: N/A
Re: Acme Miracled 4/7ch HELP
Post by remco_k »
For both 4/7 channel modes:
As far as I can tell, there are 25 patterns. You choosed the gobo channel to control those, so you should fill in 25 gobo's instead of the current 18. Ofcourse also expand the gobowheel tab. It currently ends at 170. Should go on to 250 in steps of 10.
But, using the gobo channel(s) is a problem for the 7 channel fixture mode:
FS maximum is 3 gobo channels. So its better to not use the gobo configuration at all as they won't allow you to control 4 'gobo' channels.
I've attached a modified fixture file:
- Removed the gobo config.
- Filled in 4 Pattern/Chase channels (P/C 1...4). (channel description tab)
- Changed shutter and strobe channel from 3 to 6.
- Changed intensity channel from 4 to 7.
- Filled in locate values (channel description tab)
But, now the patterns/chases can't be controlled from the gobo channels, ofcourse. You could use macro's for that instead.
Creating the 4 channel mode is exactly the same. But with just one P/C channel.
Miracled 7ch.pff
(2.67 KiB) Downloaded 91 times
This file is an example, though it could work. It needs to be expanded with macro's when you want more control over it. (Use macro's in place of gobo's). How you fill that in, is up to you.
You could create 1 macro that sets 4 patterns/chases to something, or create a macro that sets one pattern/chase to something.
Pmarten8
Post by Pmarten8 »
Still bit puzzled over the macros how i build them for the pattern and chase any chance you can do first two/three so i can see how there done then i can finish it
Thanks Again
Pmarten8
Post by Pmarten8 »
Ive got this almost wrapped up but having problem with fixture when building sequence ive manage to bring this fixture home with me know so i can use it in online mode
ive got it all set-up and working but when switching to Sequence builder the fixture dose not respond to any input also sequence builder is still in offline mode but i have the light ridged up so why should it still be in offline mode
Latest Version 7ch with all 25 pattern/chase macros programmed and a set of 5 custom slots that can be programmed by user and 33 new Images for fixture creator
Miracled 7ch v1.0.4.pff
(27.85 KiB) Downloaded 85 times
Post by LJ_krede.dk »
you are in offline mode because you have running sequences or have the cue window open.
The purpose is that you can program fixture during running a show. all dmx from running sequences will be send out to your interface. . if you have the magic3D running you can see what you are doing in offline mode
Pmarten8
Post by Pmarten8 »
Perfect
You were spot on
because i had the cue table open i closed it and i can now do sequences
