Use DMX To Make Ambilight!
Have a Tip? Share IT!
Video: http://www.youtube.com/watch?v=toUNTLIzo_Y
Use Dmx to make Ambilight!
i was bored, lookt at google and came with this :D and i'm going to share it with you.
i used 8 led pars 5channel works with Enttec open/pro, velleman, DMX4u/all and more
when i used this program the led pars flashed a lot but i see now that is solved.
Also you need a very Fast PC i used a AMD2x3000mhz 4GB and a Nvidia 8800GT klok=660mhz with 512ram
and sometimes i had a delay. i only had this when i used .mkv File's.
also used with a Usb video-in Device this also works.
Download--> http://gvrstudio.nl/Send-the-light/ <--Download
Sabazios
FreeStyler Version: 3.5.1
I Use FreeStyler for: Film
Re: Use DMX To Make Ambilight!
Post by Sabazios »
hi, the file is down ... wanted to experiment a little. have a nice evening!
Return to “Tips from the Pros!”
