TCP/IP IP Address
Android Dev (Moderator)
FreeStyler Version: BETA
Re: TCP/IP IP Address
Post by Mattotone »
go to start
run
type cmd
press enter
this opens a command terminal.
type ipconfig
press enter
and look for a valid ipV4 address
Post by Mattotone »
More than likely port 3332 is not forwared to your windows instance.
Not sure how you would do it thou as i dont have mac
