Cue support
Features confirmed that have a developer but not yet completed. will list details of feature and track progress.
completed features. once a feature has been finished it will be moved to this subsection and locked.
cirrus
FreeStyler Version: 3.3.2
Twitter: http://twitter.com/_cirrus_
Cue support
Post by cirrus »
I took the task to implement support for running cues and control the speed.
Initial screen-shot attached, code is checked into the SVN but not fully functional at the moment, will continue the next days.
Cheers
Dominik
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Cue support
Post by Mattotone »
like the look, with your help this software should really come along now.
iv noticed in the code that you plan to track the sequence state, this is something i had to do with the goMonkey. There currently is no way to set a sequence as go or stop you can only toggle its state (i have requested this feature) all will work fine untill the user toggles the sequence from FS rather then the app and then the app will get out of sync.
Return to “Assigned feature development:”
