Tape Trick
Nothing about FreeStyler just General Chat.
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Tape Trick
Post by matt »
Still using Duct Tape for your cords?
Sick of that Sticky Residue but want the same strength.. Check out Gaffer Tape!
http://en.wikipedia.org/wiki/Gaffer_tape
Trust me its worth the extra dollar or two a roll!
Matt Hankosky
flickr.com/photos/mattxhank
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Tape Trick
Post by Mattotone »
Never use duct tape its horrible stuff, hard to tear, impossible to get on cables and incredibly sticky.
Gaffers Tape all the way, its a cloth based tape, easier to tare for when you need thinner strips, easy to remove and a lot less sticky (there are different grades).
Also if your tiered of cables getting tangled buy some doubled sided velcro.
Coil your cables using the over under technique and when your done velcro the coil together. Alternatively iv used shoe laces tied to the cable ends and then tied in a bow around the coil.
Allways coil cables, never wrap them round your arm, tie them in a bow, wrap around its self. It damages the cable, puts nasty kinks in it and never lays flat again. If you coil your cable using the over under method your cables will never tangle will allways lie flat and will last longer.
Remember without cables you cant do your job!
matt
Admin
Re: Tape Trick
Post by matt »
Also, This stuff is awsome
Put a nice Caution Marking.
Matt Hankosky
Jaykie
Re: Tape Trick
Post by Jaykie »
Lol have used that tape last thursday for taping some cloth to a table :P looked kinda funny with the black and yellow :P couldn't find the gaffer :P
Re: Tape Trick
id rather use police tape! :ugeek:
Return to “Off-Zone”
