LED Trix in Cues Topic is solved
Te_za
LED Trix in Cues
Post by Te_za »
Hi All,
I would like to Save LED Trix in Cues, Is this possible with Free Styler.
I'm a Lighting operator, used to consoles like the ETC ION, and the Strand 520i.
figuring out if I can use Freestyler as a replacement for Hog PC??? as its just a bit cheaper than buying the Hog3 dongle.
I used LED trix to run a 4x3 LED strip wall the other day at a show, and was impressed with what you can achieve with a piece of free software.
dmxlighting
FreeStyler Version: beta
Re: LED Trix in Cues
Post by dmxlighting »
Sadly not at this time.
The suntrix and ledtrix plugin's are standalone programs within FS, much like the dmx400 chaser control.
I have no idea if our glorious developer has plans to change this but I would say probably not. It is what it is.
I have moved to using FS from using a zero 88 leap frog and have never looked back so you have made a good choice! :fs:
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
I know this thread was done a year ago. I was just wondering if anymore thought was put into this regarding adding LEDtrix scene to a cue? I'm only asking because I can see benefits in this. :D
Thanks.
Return to “Suntrix & LedTrix plugin”
