My first post on this forum, and it's a feature request right away!
I found out that the submasters can be controlled remotely by MIDI to some degree, but I'd like to have more control.
My request: could FS support a command like this:
Submaster ##, "select and run"
it would be assigned to a specific control change, and the value of the control change would determine the specific cue which needs to be selected and started, right away.
(therefore, 128 cues could be selected right away within one submaster)
A couple of examples:
Channel 16, CC 1 is assigned to submaster 1
so, CH 16, CC 1, value 10 would select, and run cue 10 of submaster 1
so, CH 16, CC 1, value 5 would select, and run cue 5 of submaster 1
This would eliminate the need for various GO / BACK / RUN calls, and it would simplify the task of creating a "light controlling" midi track.
(needless to say:
