- Engels -
is it posible to make faders instead of wheels for the intensity channels and i'm talking about the touchscreen userinterface 2
but also you can't move the wheels.
- Nederlands -
is het mogelijk om "faders" in plaats van "Wheels" temaken, voor de GOBO/COLOR/INTENSITY channels en dat voor de touchsrceen userinterface 2.
en als je een "wheel" hebt neer gezet moet je hem meteen goed zetten want je kan hem niet meer verplaatsen.
vriendelijke groet Emile ballard
Touchscreen / Userinterface 2
- Spirit
- FreeStyler Version: 3.5.9
Re: Touchscreen / Userinterface 2
at the moment there are only wheels for the user interface 2.
there should be an option in the drop down menu top left corner so you can move buttons and wheels to the desired location on screen
- Spirit
yes I no but if you place the wheel you can't move the wheel anymore even with the "Move buttons/WHEEL" option on
now i see first you must 1.place the wheel and than you must 2.turn the option on.
if 1.turn the option on and than you 2.place the wheel you can't move the wheel.
AND I WANT FADERS!!!!
Greats, Emile Ballard
- Spirit
is it also posible to make like dedicated faders
example: i have 4 scans ch1: dimmer/stobe ch2: gobo ch3: tilt ch4: pan and ik want that 1fader serves CH 1/5/9/13 and only value 0 - 150 because that is mij Dimmer value
sorry for my terribly English but i try doing it i get better
djmaq
That's exactly what I'm searching for. If you have a touchscreen that can't handle more than one contact at one time (that means no multitouch) it's nearly impossible to turn these encoder wheels. (Haven't tried it with a multitouch display. Might be better but a multitouch screen is even more expensive as well).
So please please please give us an option to turn these encoders into faders. Is there a plan to do implement that?
greetz djmaq
greetz djmaq
- Spirit
No i don't have that problem you describe about the Single touch and multi touch.
the big issue for me is, if you place a encoder on your screen and drag the encoder you will get very fast at the end of you screen.
multitouch isn't expensive or yes it does but look at this screen ProLite T2250MTS it's realy cheap a 22"Multitouchscreen, Win7(with xp you only have a single touch beta driver)just for 250€
or 342 Dollar
And yes i did already maked a feature request look at the FSBT
http://www.freestylersupport.com/bugs/main_page.php issue 0000043
http://www.iiyama.com/nl_nl/producten/p ... 2250mts-1/
Greets
Greets
