Martin 812's and Freestyler [FIXED]
- FreeStyler Version: 3.3.1
hi im new to the dmx lighting i have 4 martin roboscan 812s i want to use throught freestyler in stead to the big martin box i have wich is all pre programed i have bought the jms usb2dmx all seams to be working from what i can c but the light dose noting i just have the one connected to try this out i have checked that the lead is working and the computer says it is but the light is not doing enything the bulb has striked and the light is ready to go but notting eny sugestions ? thanks adam
- LJ
- FreeStyler Version: 3.2.8
Re: jms usb2dmx no out put
I just posted in an other topic the same:
Go to Setup -> FreeStyler Setup -> Interface setup -> Controller and make sure that your interface is selected.
But in fact the interface you bought will work: I am using the same
I had some trouble some days ago:
I updated to Windows 7 64Bit and the driver deliverd on the CD was not working. There is a new driver version on the home page so perhaps you want to download and update your dirver: http://www.usb2dmx.com/index.php?option ... &Itemid=26
- dmxlighting
- FreeStyler Version: beta
Before you get too excited, you need to check that Martin 812's respond to DMX and NOT Martin Protocal (Martins own version of DMX).
To my knowledge there was never a software upgrade to allow 812's to decode DMX512. There was one for the 218 though.
It is possible to get a special box made by Martin that will convert DMX into Martin protocal. I dont think its still avalible to order from Martin but I have seen them pop up on Fleabay from time to time.
Anyway good luck
Anyway good luck
- LJ_krede.dk
- FreeStyler Version: 3.3.7
dmxlighting wrote:Before you get too excited, you need to check that Martin 812's respond to DMX and NOT Martin Protocal (Martins own version of DMX).
read more and check the illustrations in the manualRoboscan 812 manual, page 7 wrote: Connect the Serial Link
The RoboScan 812 may be used with DMX and Martin protocol controllers. The RoboScan
812’s XLR connections are configured for Martin protocol controllers such as the 3032.
When connecting a RoboScan 812 to any DMX-standard device, you must swap pins 2 and
3 with a phase-reversing cable.
/LJ_krede.dk
Aalborg, Denmark
Aalborg, Denmark
- FreeStyler Version: 3.3.2
Yep was going to say this but you beat me to itLJ_krede.dk wrote:dmxlighting wrote:Before you get too excited, you need to check that Martin 812's respond to DMX and NOT Martin Protocal (Martins own version of DMX).read more and check the illustrations in the manualRoboscan 812 manual, page 7 wrote: Connect the Serial Link
- dmxlighting
This all still depends on how old the software in the unit is. I sure that early 812 software would only support Matrin protocal. ?
thanks for the advice i have reversed the polarity of the cable and it works thanks evey one i can now enjoy and make lighting shows !!!!!!
- dmxlighting
Im please you found the answers. Ive changed the title of this thread as it may help others in the future.
- LJ_krede.dk
Re: Martin 812's and Freestyler [FIXED]
rule of thumb: Always read/browse through the manual before you are dealing with new equipment you never have used before AND when you have some issues... it can save you for a lot of time AND trouble because you can find the most common answers in the manual. Especially when you are dealing with some cheap fixtures where more attributes than one is controlled by one channel or have a lot of modes and features you set on the fixture itself.
I don't know how many times my colleges had problems connecting or controlling fixtures where I could help them instantly based on I had read the manual for the used fixtures AND lighting consoles.
/LJ_krede.dk
Aalborg, Denmark
Aalborg, Denmark
- remco_k
- FreeStyler Version: N/A
Real technicians never read manuals. Thats for wimps.
I know I don't....
Just joking...
LJ_Krede is so right, although I must admit I always/most of the time start without even have a look at the cover of the manual.
If something doesn't work out like expected, its early enough to have a tiny look in the manual.
I know I don't....
Just joking...
- dmxlighting
In my world user manuals are called 'Girls Books'!
Because they are only to be read by girls and ladyboys
- LJ_krede.dk
remco_k wrote:Real technicians never read manuals. Thats for wimps.
soooo. what are you saying heredmxlighting wrote:In my world user manuals are called 'Girls Books'!
I will be the first one to laugh and yell "i told you so" in your faces when (not "if"....."When") you have been dealing with errors for hours in stead of looking in the manual and finding the answer in 2 minutes
okay, maybe you don't always ave to read the whole manual. you should know how to plug in the power cables and connect it to DMX. but i like to have everything under control. that's why I always make my own fixture files or compare them to the manual before the setup, then I know for sure the problem is not there if any problems should arise.
one day i should program some DTS pro Spot 250 with a pearl. i looked at the fixture file for the pearl the day before and found out i couldn't turn the lamp on and off from the pearl. I modified the file and didn't have to climp in the rig to turn on the lamps on the day i should program them. also when reading the dmx protocol i found out some nice features the DTX pro spot had, in stead of programme that manually.
call me a ladyboy if you want... at least I would be a well prepared one
/LJ_krede.dk
Aalborg, Denmark
Aalborg, Denmark
- I Use FreeStyler for: Eurovision
- Twitter: www.twitter.com/trikkitt
I had a few issues running the Martin RoboScan 812 in 7 channel mode. Looks like the file supplied with Freestyler is quite seriously wrong. It made references to channel 8 (on a 7 channel device!), which appears to affect the values of the next fixture on DMX. There are quite a few other errors, it really does feel like the 812 fixture provided has never been tested.
Is there somewhere I should share the updated file?
- LJ
If you created a fixture file it is always a good way to use the FreeStyler Fixture Files - User created Downloads section to share it
