Hey guys.
I can't seem to find a fixture to my new Stairville LED par 64 lamps :s
i have tried to make one myself, but i just can't figure it out..
Anyone can help me?
It has 5 channels:
Channel 1 value
0-63 - RGB Control, CH2= RED, CH3 = GREEN, CH4=BLUE.
64 -127 - 7 color fade, CH5=Speed control.
128 - 191 - 7 color change. CH5 = Speed control.
192-255 - 3 color change. CH5 = Speed control
Channel 2 value
0-255 - Red color 0% - 100%.
Channel 3 value
0-255 - Green color 0% - 100%.
Channel 4 value
0-255 - Blue color 0% - 100%.
Channel 5 value.
0-10 - No function -no speed.
11-100 - value 11 to 100, fast speed to low speed.
101-150- no function -no speed.
151-255- speed controll by unit, by music or VAR.
Problem: Fixture LED Par 64. Topic is solved
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Problem: Fixture LED Par 64.
the stairvile par 56 fixture should do what your looking for.
it has macros for the built in functions, which are rarely used. and the correct channels for RGB
Hej Emil
jeg går ud fra du er fra dk ???
try to upload your exported fixture file (file --> export in fixture creator), then we can find out whats wrong and you may learn something so you can create your own fixtures in the future.
PM mig hvis du skal ha noget hjælp...hvis det er skal jeg nok lave den lampe til dig
Mavi
You can use the PAR 56. It works great for me so it should also do for you!
If you want, you can change the picture (use the fixture creator to edit the fixture file) to a PAR 64
- Mattotone
The stairville par 56 and par 64 are identical -size. Same functions, same number of LEDS and same DMX channels.
When i created this fixture i added the most common functions i needed. The built in programs are accesable via macros you can adjust the speed using the sliders on the right.
I think i even used the par64 image for the fixture.
matt_steel
Hello friends in music.
I can't locate the fixture for Venue LED PAR64 lights.
Does anyone know of a compatible fixture that works?
Thank you.
Thank you.
