Another bug - shortcut keys
All previous beta Bugs will be moved to here on release of a NEW Beta
Locked
Crrispy
Bug Zapper...
FreeStyler Version: 4.1
Post by Crrispy »
Hello,
Tried to file it on the bug report page, but atm the "send" button doesn't work, it does nothing.
Bug with the shortcuts keys:
Assign a key to button 1
Save & close
Go back to keyboard shortcuts.
Assign the same key to button 2.
It is de-assigned from button 1 automatically.
Save & close.
The key still toggles button 1 ...
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Another bug - shortcut keys
Post by Mattotone »
The forum has been going through some upgrades, all should be well now.
Please try your report again.
[bugreporting][/bugreporting]
Crrispy
Bug Zapper...
Post by Crrispy »
12:35 here, still doesn't work, once the report filled in, the "Send" button just does.. nothing at all.
Post by Mattotone »
Crrispy wrote:12:35 here, still doesn't work, once the report filled in, the "Send" button just does.. nothing at all.
Works fine hear at my end.
Post by Mattotone »
try clearing your cache / temp internet files or a complete refresh ctrl F5. you may still have an older version saved on your computer.
Crrispy
Bug Zapper...
Post by Crrispy »
Cleared the cache.
Cleared history.
Deleted all the cookies.
Disabled my ISP's proxy in IE.
Closed IE.
Restarted IE, went to fs.djsupportonline.com
Filled the form.
The "Send" button still does nothing at all. Worked fine 2 days ago on the very same machine.
Where do we leave bugs of the bug report? LOL :mrgreen:
Post by Mattotone »
are you using the bug report on this forum or on the djsupport site?
what version of flash are you running?
thats because the file on fs is the file on forum now they are both identical but fs.djsupportonline.com wont work due to it be programmed to work only on forum i will shortly be notifing people that the must and CAN ONLY use the forum bug reporting!
Crrispy
Bug Zapper...
Post by Crrispy »
OKAYYYYYY, haha, I was still trying to use the one on djsupportonline.com, 'cause there are still several links to it, including just above the message I'm currently typing :lol:
That must be because I only have "half a brain", 90% of this half being used to get FS to do what I want to do ;)
OK, so bug report filling after dinner, and some programming, too. :fs:
Locked
Return to “Previous Beta Bugs”
