Often when U use PAR64 and other lights U use 2 PAR64 at the same DMX channel...
And when U put the fixture at the screen U can only put one of the 2 PAR64.....
It would be nice 2 make a Copy of any fixture and place it on the other place...
And then U would have 2 fixtures controlling the same DMX channel....
Copy of the fixture...
dboykin
Re: Copy of the fixture...
You can patch it that way. Make another fixture and remember it's dmx channel, then in add/remove fixtures at the top right hand corner click on patch.. go to the dmx channel you just added and change the value of that dmx channel to the dmx channel you want it to change also. Then whenver you change one of the fixtures it will manipulate both.
