[REQ] Disable sequence when set to "non repeat"
horstefan
Post by horstefan »
Hello, i use freestyler with a bcf2000 and i noticed something last weekend
I was using a sequence that i set to "one time" instead of repeat
when the sequence ends the sequense remains on "play"
this required me to turn it off and on to use it again...
wouldnt it be better if sequences in this mode were automaticly stopped if its set to "one time" ?
Kind Regards,
Stefan Wempe
ps:
less important: when "one time" and "reverse" are both enabled the sequence wont run
dmxlighting
FreeStyler Version: beta
Re: [REQ] Disable sequence when set to "non repeat"
Post by dmxlighting »
horstefan wrote: Hello, i use freestyler with a bcf2000 and i noticed something last weekend
Cool - best way of using FS (in my opinion!)
Yeah it does do this. I think it was designed to 'stack' sequences and play one after another and notthe same sequence over and other again.
I understand what you want here. I don't think it will be changed though. Try using the submasters and the cue window together instead.
I tried this and my experience was that the sequence would run but not stop. It was ignoringthe 'run one time' and just looping the sequence.
Return to “Ideas and Remarks”
