Run multiple cuelist / select multiple buttons? Topic is solved
mr.quickly
Post by mr.quickly »
Hello everybody,
is it possible to select multiple cue buttons?
I've created some for my PAR-56 spots and some for my LED effects. If I click on a PAR-56 show, the show runs, but when I click on a effect button the PAR-56 show stops with the last scene and only the effect show is running. I hope you could understand me.
Re: Run multiple cuelist / select multiple buttons?
Post by LJ_krede.dk »
What do you mean about "effect button"?
If you refer to another cuelist button, the answer is simple: you can only run one cuelist button at the time. it is not a bug,
mr.quickly
Yes I mean another cuelist button.
How do I run multiple shows?
If I insert them into the left side under another I could press the play button and scenes are played together.
That Is what I want, but there are not enough lines for all of my shows. Is there a way to increase the line number?
Mavi
Post by Mavi »
No, you can not increase that number. But you may take a look at the "Using Cues and Submasters" Wiki page here: http://www.freestylersupport.com/wiki/submasters
I made another post to a similar problem where I descripe what submasters are used for. You can finde it here: http://www.freestylersupport.com/fsforu ... 174#p10420
Hope this solves you problem. If not, you will have to reduce your sequences and put multiply of them together to only on sequence. But there is no way to run more then 20 at the same time.
mr.quickly
I don't need to run more than 20 at the same time, I only like to have more scenes to activate (clickable) on one page.
I will have a look at your posts and the wiki.
Edit:
I've look a you post. I think I will use the submasters. I've tried just a minute ago and in the software the scenes are running parallel.
But I'm not getting more than one cue to the submaster as displayed in the wiki. If I drag and drop the second the first will be removed.
Mavi
Post by Mavi »
mr.quickly wrote:If I drag and drop the second the first will be removed.
You have to drop the second one in the second white field, the third one in the third field, ...
mr.quickly
Thanks Mavi,
I'm a little bit confused :?
I've to insert more cues into the cuelist. When I drop one of those into the submaster field they are all displayed there and I could choose the one I like.
That is I think the thing I need.
Thank you very much for your help ;)
Mavi
Post by Mavi »
Ok, I will try to explain again. You put up to 20 sequences, lets say for your LED Pars, in one cue list. You save this cue list. Then you create another cue list, lets say for your Scanner, and save this list to. Then you open the submaster and drag and drop the LED cue list to the submaster window one and the scanner cue list to the submaster windwo two. Then you can run one sequence out of every list at the same time. The squences running are displayed in the cue list. Therefore you can run 20 different seqences in 20 different cue lists (in the submaster) at the same time.
Hope you understand what I want to say. If you are from Germany you can write me a PM and I will try to tell you in German what I mean ;)
