Chauvet - Techno Strobe RGB
Shannon D
Post by Shannon D »
Here is the Chauvet Techno Strobe RGB fixture file. Enjoy!
Chauvet_TechnoStrobe RGB.pff
(31.11 KiB) Downloaded 166 times
youngkwangk
Re: Chauvet - Techno Strobe RGB
Post by youngkwangk »
Hey, intensity won't properly work :/
I think it's because Techno Strobe RGB's range of intensity is from 255 to 0, instead of from 0 to 255 (like in most fixtures)
Do you think there's a way to fix it?
making min 0 and max 255 makes it work, but reversed
Thank you,
Young Kim
Return to “Chauvet”
