Rouges Gallery
Nothing about FreeStyler just General Chat.
dmxlighting
FreeStyler Version: beta
Rouges Gallery
Post by dmxlighting »
I think its about time that the 'Mug Shots' were posted.
Don't be shy lets see what you look like.........
Here is me....
I was in a happy mode this day!
Reason: Tried to get picture to display reather than a download.
Re: Rouges Gallery
Erm I'm here ->
Onge
Re: Rouges Gallery
Post by Onge »
DJ Support wrote:Erm I'm here ->
Who is that man :?: :D
Onge
Re: Rouges Gallery
Post by Onge »
OK here is one of me.
Me on a good day. :? :shock: :o :roll:
Onge
Re: Rouges Gallery
Post by Onge »
Getting pictures to display must be something to do with size, I do not mean upload size, I mean X & Y size.
All I did was take Lee.jpg and reduce it in size by 1% and it displays. I tried the original in both jpg and png and would only allow a download. Yep this is a png version of that but I am sure a jpg version would also work.
So if a picture does not display then try and reduce it by 1% and see if that makes a difference.
Re: Rouges Gallery
I think Its a setting I have set in the forum software... I'll have a little gander and update you tomorrow..........
Re: Rouges Gallery
Maximum thumbnail width in pixel:
A generated thumbnail will not exceed the width set here. 400 px
Minimum thumbnail file size:
Do not create a thumbnail for images smaller than this. 12000 Bytes
Maximum image dimensions:
Maximum size of image attachments. Set both values to 0px by 0px to disable dimension checking. 600x800px
Image link dimensions:
Display image attachment as an inline text link if image is larger than this. To disable this behaviour, set the values to 0px by 0px. 300 x 300 px
Re: Rouges Gallery
If you think that needs changing open a topic in the Cafe ;)
Onge
Re: Rouges Gallery
Post by Onge »
@DJ Support
These are inline pictures, just browse for the picture, place inline, nothing else added, sometimes a file description/comment. Some display, some display as a link to download.
I never have any problem if the pictures are hosted elsewhere and then pointed to with an image tag. I am pretty sure that is the same for others.
I used to host all my pictures on on my server but noticed one day that LJ_krede had post a picture that was inline so started to do the same thing. Every now and then a picture for whatever reason will only place inline as a download link.
I found out that if I reduced the image (size) by 1% it did then display, I need to try it with other posts where I have pictures that would not display.
I am not saying it is a solution, it might be you have to increase by 1% or make the width or height an even number. Who knows exactly.
dmxlighting
Re: Rouges Gallery
Onge wrote:OK here is one of me.
What you dont get from this picture is that Andre is 7 feet tall with hands like baseball gloves! :D
Re: Rouges Gallery
@Onge I belive its this... Image link dimensions:
Onge
Re: Rouges Gallery
Post by Onge »
dmxlighting wrote: What you dont get from this picture is that Andre is 7 feet tall with hands like baseball gloves! :D
He is not far wrong ... I nearly p!$$ed myelf when I read that. ;) :lol:
Onge
Re: Rouges Gallery
Post by Onge »
DJ Support wrote:@Onge I belive its this... Image link dimensions:
Nope as it seems that it might be smaller pictures do not display inline. Remember I reduced the dimensions of the picture. dmxlightings picture is smaller smaller than my picture.
BUT - I have also had two pictures with identical x & y dimensions and one would display inline the other would not.
Return to “Off-Zone”
