When I make a Sequence with more then 1 step and save it and puts it in the Programable Overide Buttonscreen it only showes the first step...
Can I not use more then 1 step in the Programable Overide Button??
CUEs... Topic is solved
- djSupport
Re: CUEs...
there is a detail reason what the override buttons are for but I havent at the moment got time to explain... but basically there for static scenes i.e. one scene to run a sequence with more than one step stick it in the cue list or the submasters...
DeeJay_Bamse
Re: CUEs...
Yes I can realise that but some Overides I want to have a Set and one fade out step....
If U know what I mean....
It would be a very good thing to have a Window that U can put the sequences U use and have big buttons like the Overide buttons so U can use a touch screen at a installation so they only have 2 click on "light" for example....
- djSupport
Re: CUEs...
er tryout the touch screen option in setup and someone else on the site might be more helpfull to anymore options sorry
