Hi all, I wonder to know if somebody already succeed to have freestyler running on windows 7 64 bits ?
I know have my Monacor DMX-510USB up (and running ?)
I can see the DMX signal blinking on my dimmer, but do not see values changing on the output (all channels are 0).
I don't know if it comes either from Freestyler or the driver.
I will try to scope the signals on the RS485 to see what happens, but if a known issue is open against windows 7 pro (64bits) let me know.
Thanks in advance
Laurent
[FIXED]windows 7 64 bits Topic is solved
Hanternoz
- cyberb0b
- Commited FS Forum helper
- FreeStyler Version: Beta
Re: windows 7 64 bits
I use windows 7 with freestyler and an enttec pro without any problems.
Hanternoz
Thx Cyberbob, I will try to understand where it comes from by scoping RS485 signal and see if something is going out.
Otherwise, I will have to analyse the USB trace and see if this is in the driver.
- dmxlighting
- FreeStyler Version: beta
cyberb0b wrote:I use windows 7 with freestyler and an enttec pro without any problems.
Do u have 64bit win7 Bob ?
- cyberb0b
yes, i do have x64
dustin
Since last week I also use Win 7 x64 with an Eurolite interface without any problems.
- dmxlighting
Did you need any new drivers or did it just work with the old drivers ?dustin wrote:Since last week I also use Win 7 x64 with an Eurolite interface without any problems.
Hanternoz
double post, oops
Hanternoz
Hi all,
After some time spent on this issue, I finally succeeded in having Freestyler running on my new configuration.
2 problems were to be solved :
1/ I finally found the Monacor DMX-510USB driver on the DMX Control forum.
I will post it here so that it should help others users.
2/ I had to run FS has administrator to have the DMX running normally.
So I am glad to succeed, and I now can start playing with the Hercules DJ Console to drive my lights.
So funny
Regards
Laurent
So funny
Regards
Laurent
DMX-510_Treiber.zip- (189.24 KiB) Downloaded 888 times
