Is there any way i can get a cue to activate after another has already ran through its steps?
Also is there a way i could only have one cue running at a time when the cues are linked to keyboard activation?
Automatic Cue?
lightguy101
- FreeStyler Version: 3.2.8
- LJ_krede.dk
- FreeStyler Version: 3.3.7
Re: Automatic Cue?
I believe you are meaing sequences in stead of cue? each cue consist of max 20 sequences.lightguy101 wrote:Is there any way I can get a cue to activate after another has already ran through its steps?
yes. you can get the sequences to run after eachother. in the cue window click on the cog wheel and select "Loop all sequences". be aware when the last sequences if done running first sequence will start again
yes. you can deactivate multiselect in Setup --> FreeStyler Setup --> Preferences --> Extra options. remove the checkmark for "Cue Multiselect always enabled"Also is there a way i could only have one cue running at a time when the cues are linked to keyboard activation?
Go to Setup --> FreeStyler Setup --> External Control --> Keyboard shortcuts, and assign keyboard shortcuts for "sequence 1" to "sequence 20". when you press the key, the sequence will play. hit the key again it stops.. if you hit another key the new sequence will play and the old one stops
/LJ_krede.dk
Aalborg, Denmark
Aalborg, Denmark
