HELP! Syncing Light With Music Topic is solved
lightguy101
Post by lightguy101 »
Hello Everyone, This is my first post on the freestyler forums. :D
I have not been using freestyler for very long, so i am not that familiar with it yet but i am working on it. I would like to know how to set up a light show that is synced with music. Like a band or prerecorded. I would like be able to program a show for a song then hit one button and have the whole show run by itself.
Any Help appreciated,
lightguy101
FreeStyler Version: N/A
Re: HELP! Syncing Light With Music
Post by remco_k »
You are looking for somekind of timeline programming, FreeStyler does not have that feature. You can run sequences/cues to sound using the Sound 2 light tool, but it wont automaticly start new cues or sequences.
Post by LJ_krede.dk »
you can enter timesstamps and run a timer in the cue window, but i will not recommend it for live music on stage, it will always be out of sync
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
There is a way to timeline in FS but it requires knowledge of midi commands in FS, the knowledge of making cuelist buttons in FS and the knowledge of adding midi triggers to the audio source you are using So I can be done (sort of) but it would take ages and ages to do and really is not worth it.
I always wonder why people are so keen to have a sequence or cues that work specificly to a peice of music. However you do it its so difficult and time consuming to do. Its a bit like making a cartoon, frame by frame ......
lightguy101
OK
What if i wanted to program in scenes that activate them by pressing a button.
Post by remco_k »
What if you just read the manual (help file) and look how to use external controls like keyboard shortcuts and/or midi control.
Also lots and lots to be read about that subject on this forum. :)
paull
Post by paull »
It can be done, try to break your set into small sections and program them. then put it all together. As sais above a midi controller will definately help.
