"Subscript out of range" when creating a sequence
Disscussions on possible bugs in the current BETA.
YOU MUST FILE A BUG REPORT HERE before discussing possible bugs.
The Idea of this is :
1. Informing others of confirmed BUGS and
2. Giving other members the opportunity to confirm your possible bugs
fcprod1
Post by fcprod1 »
I get this error when i try to make a sequence. I hit ok but it does not allow me to make a sequence. Please help.
Reason: Subject edited: Date --> Range
dmxlighting
FreeStyler Version: beta
Re: Subscript out of date when creating a sequence
Post by dmxlighting »
fcprod1 wrote:I get this error when i try to make a sequence. I hit ok but it does not allow me to make a sequence. Please help.
Have you just upgraded the version of FS you have?
Have you changed something in FS (.ini file? or anything else)
If no to these questions then have you added any other software to you PC recently that may be conflicting?
Give more info if possible
Post by LJ_krede.dk »
Subscript out of date?? don't you mean Subscript out of range?
FreeStyler Version: N/A
Post by remco_k »
The error is "Subscript out of range".
Could be a few things:
1. As already said; something is wrong with the ini file. Easy solution: try a reinstall of FreeStyler, after backing up your files.
2. Could be a badly created fixture file. Try creating a sequence with some basic PAR fixture to see if that works.
More info is needed to guide you through the problem. On what moment does the error occur?
sirwesley
Post by sirwesley »
Using 3.3.9 beta:
I get the "Subscript out of range" error every time I save a "Location".
I don't see any major side effects of this error however. Are there any? Will I be able to copy my preferences to another computer and everything work smoothly, as I do all my programming on a desktop, then transfer everything to a laptop for "live" shows.
Return to “Latest Beta Bugs”
