Thanks foe Developing awesome software.
Two Cue Lists Topic is solved
bucwheat
Two Cue Lists
Is it possible to add a second independant cue list to this software. It would be nice to have one to control front lighting independently from back lighting. We use the software in a Live Band situation.
- dmxlighting
- FreeStyler Version: beta
Re: Two Cue Lists
You can use submasters to do this.
You have 5 submasters per window and 4 tabs. So a total of 20 submasters can be run at the same time. You can only run one cue per submaster.
Each submaster can have a maximum of 20 cues in it.
Have a look here for more info on submasters - http://www.freestylersupport.com/fsforu ... f=6&t=1803
Let me know if you have any more questions
Shannon D
Re: Two Cue Lists
As stated above, you can use the Submaster to achieve what you looking for. This is one way to do it, but there are other ways of course:
- create sequences using just the front lights (back lights turned OFF), save and add to cue. Name Cue "Front Lights".
- create sequences using just the back lights (front lights turned OFF), save and add to cue. Name Cue "Back Lights".
- create sequences with all lights using some nicely mixed colors and/or movements, save and add to cue. Name Cue "FAB" (front and back).
- open the Submaster and add the new 3 cues to empty submaster slots. Double click on any of the sequences in the Submaster and your in business.
I'm not sure exactly if your wanting to change the front lights with the back lights completely off or just control them independently Or vice versa. You may want to create sequences called "front lights off" and "back lights off" and add them to the "Front Lights Cue" and the "Back Lights Cue". You may also want to create a global blackout and stick it in the FAB cue. If there is something specific your trying to accomplish, let us know what lights you have and what your goal is. We will try to assist.
It's all up to you how you want things to work. You just have to be creative and use your imagination. The possibilities are endless.
- dmxlighting
Re: Two Cue Lists
Yes they are. Its only peoples imagination that limits those possibilities!Shannon D wrote: The possibilities are endless.
