FreeStyler with DMX Manager interface Topic is solved
sp1
Post by sp1 »
Keep gratitude for Your work from Freestyler admirers.
We have got used to Your software, many thanks to You. We used it with various devices which are supported by Your program.
Recently controller DMX Manager (http://www.dmxmanager.narod.ru) was widely adopted in the CIS countries. One of its features is distribution of open dll-library with the description. Many fellow workers use this controller. The software which is delivered with DMX Manager is less functional than Yours, and only in Russian.
We will be very grateful to You, if You can add this controller in the list of devices in Freestyler in new(current) versions.
In attachment materials which will be useful to You.
In advance thanks for Your attention!
DMXManagerDLL.pdf
DLL Description
(26.08 KiB) Downloaded 72 times
dll.zip
Dll Library
(43.36 KiB) Downloaded 59 times
drv.zip
Drivers
(259.89 KiB) Downloaded 57 times
Return to “Ideas and Remarks”
