New option for your fog machines? Topic is solved
honslow
Post by honslow »
Hi There
I am missing a small option in the fog machine control window. Because i have a 1500W fog machine the "Durantion" og 1S i sometimes to much and produces too much smoke in small areas. I know I can set the timer to longer periods, but it is not quite the same as small output and short periods, because that creates a smoke more like a haze and not too thick. Therefore I would like the possibility to choose a time of less than 1S, ex. 0.5S and maybe 0.25S. Hope this extension is possible in Freestyler without two much extra work?
Ys-
Daniel - Denmark
matt-the-dj
Re: New option for your fog machines?
Post by matt-the-dj »
has anyone figured out this yet as i need to drop the timer to less than 1s aswell :fs:
matt-the-dj
yeah i see what you are saying, i may have to fly this up on the rig then to get it off the stage as it really pumps out some serious smoke volume,that way i can let rip......this m/c pumps 20,000 cubic feet per minute, which is fine for the large marquee its going in, i just have to hide it and make it less conspicous :D
or just program a sequence and map it to an overide button mapped to a key on keyboard....
Return to “Ideas and Remarks”
