override buttons
alecvannoten
override buttons
Post by alecvannoten »
the question is probably answered many times, but when u use touchscreen like i do there's lot's of empty unused space under the override buttons.
it would be useful if u could fill this space up with more buttons.
why can't there be - like a matrix - somathing where u can enter the desired number of buttons in rows and columns??
GaryBonaducci
Re: override buttons
Post by GaryBonaducci »
alecvannoten wrote:why can't there be - like a matrix - somathing where u can enter the desired number of buttons in rows and columns??
Have you tried "Touchscreen userinterface 2"? It's an option in the FreeStyler Setup panel.
alecvannoten
yes, but there it's limited to 30 as well
Post by LJ_krede.dk »
that's not exactly true. there is two ways for the touch interface 2:
* Use" Overrider button tab" buttons so you can chose what the buttons do.
* what i think you want is to have more than 30 buttons visible on the same time. when you are adding buttons to the touch interface you can select "Override button ..." in stead of the "Override button 1" to Override button 30". with the "Override button ..." you can choose which override button it should activate. you can choose up to 180 override buttons. override 1 is the first button on tab 1, override 31 is first button on tab 2 and so on.
but yes.. if you are using touch interface 1 it could be nice to have more buttons, when there already is a lot of space which isn't in use
Return to “Ideas and Remarks”
