ROBE Colorspot 170 AT
jannoposti
Post by jannoposti »
here is colorspot 170 AT fixture file
djhd10
Re: ROBE Colorspot 170 AT
Post by djhd10 »
Thanks, but for some reason when i try to move the moving heads in the grid box they do not respond only when i manually move the faders on the side?... what could be the problem? and then out of 4 of my heads 2 of them keep resetting....?
FreeStyler Version: N/A
Post by remco_k »
-Make sure your fixture is in 16-bit pan/tilt mode - as this profile is created with 16 bit pan/tilt controls.
-The Colorspot 170 at has 4 different modes of which 3 are 16-bit mode (Mode 1,2 and 4) . It seems to me (looking at the fixture DMX manual) that you should configure your Colorspot 170 to Mode 1, as those DMX channel descriptions match the profile.
Ofcourse make sure you don't have your DMX addresses overlapped.
Post by remco_k »
@djhd10: I'm curious if it worked out for you? :)
djhd10
Post by djhd10 »
hi mate thanks for the help, i will be testing the lights out on saturday and ill get back to you asap thanks
djhd10
Post by djhd10 »
Hi thanks I used the software with my lightshow and works perfectly thanks for the support
MasLove
Post by MasLove »
Thanks, have very much helped!
Return to “Robe”
