Eurolite DMX Superstrobe 2700
Post by LJ_krede.dk »
(Not tested)
Manual
Features
  • DMX512 standard control (2 channels: brightness and flash-rate)
  • Brightness steplessly adjustable (0-100%)
  • Flash-rate steplessly adjustable (1-12 flashes/sec.)
  • Elaborate reflector system
  • Electronic power management
  • Including colorfilter-frame
  • Synchronizeable
  • With 3-pin XLR-connection
  • Flash-tube already installed
Specifications
  • Power supply: 230 V AC, 50 Hz ~
  • Power consumption: 1500 W
  • Dimensions (LxWxH): 460 x 240 x 140 mm
  • Weight: 5 kg
Fixture
  • Two Channels:
    • Channel 1: Strobe
      Channel 2: Intensity
  • Shutter:
    • Open: Strobe channel at 255
      Closed: Stobe channel at 0
  • Locate values: 0 at both channels
  • Default values: 0 at both channels
  • No macros
DMX superstrobe 2700.pff
(3.24 KiB) Downloaded 82 times
Return to “Eurolite”
